[BUG PREVIEW ONLY] missing layer with Join-Loop at full
dualite2
Post by dualite2 »
Hello,
I think I found a bug with a particular model and a specific setting Full Joint-Loop (tab style).
This bug exists in Kiss 1.6.3 and 2 Alpha 0.9.9.
Can somebody try if it can reproduce it.
If you need other setting files, I can give them.
The pictures :
missing layer kiss 1.6
missing layer kiss 2
Correct one with Joint-Loop at Seam :
no missing layer
no missing layer
The model :
cut_tower_no_overhang.stl.zip
model
(16.19 KiB) Downloaded 447 times
Re: [BUG] missing layer with Join-Loop at full
It's not happening for me:
Any chance you can upload the G-code please?
dualite2
Post by dualite2 »
Sorry,
I forgot to set the "notify" to yes in my profile and don't see your reply.
Well, I can do better, I can zip you all the profile/setting and the generate Gcode.
Here :
missing layer.zip
(830.14 KiB) Downloaded 455 times
Thanks,
dualite2
Post by dualite2 »
Hum, I don't push further the investigation last time but... after seeing the generate G-Code with Simplify3D it's seems the generate G-code is correct.
Then it's probably "only" a preview bug, that make it totally less critical.
Thanks,
