Top infill not touching perimeters
frozen.rabbit
Re: Top infill not touching perimeters
Post by frozen.rabbit »
This is on every layer for me, sparse and solid infill, not just top layer.
frozen.rabbit wrote:This is on every layer for me, sparse and solid infill, not just top layer.
Every layer except the first?
frozen.rabbit
I'm seeing it on all layers.
frozen.rabbit wrote:I'm seeing it on all layers.
OK, thanks. Will note that also.
frozen.rabbit
Print test for me confirmed that an overlap value of 1.9 gives equivalent results as a value of 1 in prior releases.
Layer 1:
Layer 2:
To me, the first layer looks about how I would expect, whereas layer 2 does not.
frozen.rabbit
You're right, 1st layer is right with overlap of 1, but every layer after is not overlapping the perimeter.
sinned6915
Post by sinned6915 »
There is an issue with the Loop/Solid Infill slider under Profile -> Printer - >Hardware.
It is marked as 0-2 now where it used to be 0-1.
Add 1.0 to your old values and it should be the same as it was in 1.6.3
