KISSlicer 1.6 Tutorial Videos and Blog
3DBastler
Re: KISSlicer 1.6 Tutorial Videos and Blog
Post by 3DBastler »
Very good tutorials which I can follow and well understand even if they are in foreign language for me.
One question, you are talking about your printer*s*, do you own a Prusa I3 MK2(s) printer too?
I am talking about ALL printers. I own 14 printers and one of them is a Prusa i3 MK2S. I also have a Lulzbot, several SeeMeCNC Rostock MAX (V1, V3), Ultibots D300VS and D300VS+, Mini Kossel, K250 delta, a home brew CoreXY, a Huxley (RepRap), and several others.
3DBastler
Post by 3DBastler »
Respect!
Tuning Wizard mini-series
I just posted the first of a 5 part mini series on using the new KISSlicer 1.6 Tuning Wizards
Before calibrating flow rate, Preload and destring, your extruder needs to be well calibrated. Calibrating an extruder is a bit of a chore so I developed a 3D printable fixture to hold a common digital caliper. I show how to use this to easily calibrate your extruder's E-steps. Here's the video: [url=Here's a tutorial on calibrating your extruder. I needed to complete this before publishing the KISSlicer Calibration Wizards to calibrate flow rate, Preload, and destring. All of these require a well calibrated extruder.
My technique uses a simple (and inexpensive) digital caliper and a 3D printed tool that I developed to simplify and improve the calibration process. The printable files are linked in the video's description. Here is the video: Extruder E-step Calibration
Getting Started Sequence
I updated the index post to include a preferred sequence to help folks new to KISSlicer get started:
KISSlicer 1.6 Tutorial Videos and Blog Index
Musings on Blobbing and Stringing - Part 1
Set up for Part 2 - which will have KISSlicer stuff in it.
BoriSpider
Post by BoriSpider »
Was there suppose to be a link in your last post Michael?
Fixed. However, the master index at the very start of this thread had the link correct.
Awesome videos Michael. It's not easy to give a presentation without a lot of "ums" and on the fly searching for the right word, but you did. Your videos contain a lot of helpful information and are very smooth.
