Big Z-lifts during print
Tutorius
Post by Tutorius »
i am using the new release of KISSlicer 1.6, and have problems on some models.
I have tolde the nozzle to lift before a move up 0.3mm, and it does that on most moves.
But some moves act different, the nozzle is raised by a bigger value, the nozzle remains for a second or two at the high place, then it is lowered again and the print continues.
That has a bad result, cause my cooling-system is raised, too, and the printed PLA does not get the air as it should.
I have added tow pictures, taken from Repetier-Host, to show a normal move and a bad move.
Any suggestions? Is that a feature that i need to disable? Or is that a bug?
Thanks for your suggestions and answers!
Edit: Have found the GCode
; Post-layer lift
G1 X99.176 Y103.043 Z8.45 E0 F210
; END_LAYER_OBJECT z=3.700
; BEGIN_LAYER_OBJECT z=3.950 z_thickness=0.250
; Blending Fan to Cool (98.5% blend)
The head is not lifted to 4.25mm, it is lifted to 8.45mm, that is 4.2mm too much ...
Re: Big Z-lifts during print
This normally happens when the layer is printed too quickly. and then has to pause at the end of the layer.
What is your Settings/Material/Min Layer time set to?
Tutorius
Post by Tutorius »
Thanks for your answer. This helped me finding the solution.
The minimum time is set to 6 seconds, but i thought the slicer would print slower to achieve the longer printing time, not to lift the nozzle 4mm and stay there for an amount of time...
I have found the "guilty" parameter for this now. It is the parameter "Cool" in flow adjust (Material-settings). I had to rise this value. The slicer "thought" that it could not cool that amount of material and made this pause on some layers.
I think that i will do some tuning with the parameters, but on the other side, the parameters for one-loop-prints as i do here are a bit special, perhaps just disable this feature by rise this value to 100 or so...
Yeah, KISS will slow down the layer according to Flow Adjust/Min, but after that, it will list and pause.
FWIW, my settings, PLA:
Min Layer = 1s
Min = 0.25mm^3/s (140 E Steps/mm)
Max = 10mm^3/s
Cool = 0.75mm^3/s (although I think this could be a little higher)
The cool parameter is for un/partially supported extrusion.
