KISSlicer 1.6 Beta Feature Requests
Re: KISSlicer 1.6 Beta Feature Requests
pjr wrote:
lonesock wrote:with Peter's invaluable help again
Well I guess I just volunteered for that as well then ;)
You have no choice, humankind depends on you ;-)
All humanity, plus my sanity! [8^)
plus my slicer fantasies
xmas75
Post by xmas75 »
Can you add notes field to each Printer G-code?
I'd like to store sample codes, or notes in it, thats I didn't want to print to the G-code.
xmas75 wrote:Can you add notes field to each Printer G-code?
Yes, simply start the line with a semicolon which treats the line as a comment.
Please add the feature for the user to be able to select the order in which KISSlicer starts printing the parts.
Olivier13
Post by Olivier13 »
inventabuild wrote:Please add the feature for the user to be able to select the order in which KISSlicer starts printing the parts.
+1
http://www.additec.fr
Olivier13
Post by Olivier13 »
Hi
Like in old KS :
- See all layers : like in old KS, by moving the Z Value cursor to Zero (disable in new KS) to the bottom(down), we are able to see all layers. Not only with new checkbox feature "Draw all layers below...".
- Support Tab Object/interface : the flow gain in old KS was a nice feature for fine tune
Brim Inside :
- Can we have an option to make/have brim for holes inside parts (see pics)
xmas75
Post by xmas75 »
I often use the OpenSCAD was there and the mouse buttons are reversed. Can you give me an option to change the buttons (pan/orbit)?
frozen.rabbit
Post by frozen.rabbit »
Bring back Flow Gain for support material.
Had excellent support material removal being able to reduce flow by 95%. Now support is a bit harder to break away, and interface layer sticks to the model a bit more.
Does support width affect flow rate now?
