PLEASE PLACE ALL BUG REPORTS IN THIS THREAD
I will then summarise them for Jonathan
Thanks in advance
Not recognising where support is required - see https://www.thingiverse.com/thing:635497/#files (funBart)
https://www.thingiverse.com/download:3767633 "Segmentation fault" (Ubuntu 17.04 64x, 24Gb Ram - OK on Windows build) (demonx)
MAC - on screen text gets corrupted occasionally
EDIT: The above items are those currently outstanding for V1.6. Removed items have either been addressed in software, documentation or moved to "Feature Requests".
abuharsky
Post by abuharsky »
bed temp is always 80C
abuharsky wrote:bed temp is always 80C
For me, bed temp is what I set it to. Do you have any more information? Screenshots?
abuharsky
Post by abuharsky »
So, settings ->
Снимок экрана 2017-07-02 в 13.45.52.png (83.23 KiB) Viewed 23499 times
But in the Start GCode line
"140 S<BED>" -> "140 S80" always
abuharsky
Post by abuharsky »
Next bug with seam and ooze
Look ->
https://www.youtube.com/watch?v=j1Emsc7iIko
after each loop extruder moves up and wait about 1 second. This happens only on heights Z > 20mm
Min Layer time is set to 3sec, and "Preload" calibrated (0.55us)
Download test model -> https://drive.google.com/file/d/0B8dro0 ... sp=sharing
abuharsky wrote:But in the Start GCode line
So I test-sliced with similar parameters:
My G-Code came out correctly:
T2
M201 X1500 Y1500 E900	; set default acceleration
M301 P23.14 I1.78 D75.12 	; set PD for extruder heater
M304 P56.09 I2.39 D328.54 	; set PID for bed heater
G21 				; set units to millimeters
G90 				; use absolute coordinates
M83 				; use relative distances for extrusion
M140 S100 	   		; Heat the bed
M104 S170
M190 S100 	   		; Heat the bed
M109 S170
So I don't quite know what is happening for you.
Can you please save the project file and upload that?
abuharsky wrote:Next bug with seam and ooze
That's a minimum layer time wait to allow cooling, but oozing is happening during the wait. Doesn't look as though the destring is happening.
Can you please zip up and upload the G-Code file?
abuharsky
Post by abuharsky »
I think this is the same problem in my two reports.
Im using mac versions, looks like settings not applied.
My settings via UI
Settings in the gcode
Снимок экрана 2017-07-02 в 15.35.41.png (62.73 KiB) Viewed 23497 times
test2.gcode.zip
(696.47 KiB) Downloaded 506 times
abuharsky
Post by abuharsky »
[SOLVED]
I removed all settings and setup new. After slicing in the gcode - correct settings.
abuharsky wrote:[SOLVED]
Great, thanks. I have this listed for Jonathan.
