Hello everybody
The 3d printer to the print head a bit bulky there is the way to modify the self-positioning of multiple pieces,
it would be useful to me that they were more distant
The distance is determined by the "Inflate Raft & Prime gap" and "Brim Dia." in the "Support" tab. Rotating the part also has an effect.
You can also play with manually opening the part several times instead of increasing "Count". This provides you with the option of having different rotation angles for each copy.
Usually, however, you want to keep the distance between parts small for short travel moves, unless you want to print them one after the other ("Sequential" as the "Multiple Object Print Order" setting in the "Misc." tab"), in which case also the "Extruder Clearance" setting becomes relevant for object distance ("Printer"->"Extruder Hardware" tab).
