Hi all,
I've requested this in the BFB3000 forum but I think it's a very quiet spot, so I'm doubling up the question here. I have downloaded some .ini files from that forum to set try a print as I've having a layer shift issue that might be software, not hardware related. Can anyone tell me how to add the .ini files to Kisslicer?
Cheers,
OLC
Adding .ini setup files for Kisslicer
Re: Adding .ini setup files for Kisslicer
if the .ini files are named as the original .ini files, such as _printers.ini, _supports.ini, _styles.ini or _materials.ini, just replace the ones you already have alongside the kisslicer executable, or copy the executable into a folder where those files are. Kisslicer should recognise the .ini files, if they are structured correctly, and load them.
regards
M
regards
M
