Quad extruder; Crowning paths printed with wrong extruder
I have noticed this on a few occasions, but it doesn't happen all the time.
This layer of the model uses 2 extruders, T0 and T2. The small area bottom right is T2 and the larger area is t0, but the crowning path in the red circle is printed with T2.
Here's the generated GCode:
; 'Crown Path', 0.4 [feed mm/s], 22.7 [head mm/s]
G1 X101.28 Y116.7 Z12.7 E0 F9000
G1 X101.28 Y116.7 Z12.2 E0 F1500
; 'Destring Prime'
G1 E5 F2100
G1 X101.19 Y117.34 E0.0107 F1364.8
G1 X101.36 Y117.44 E0.0033
G1 X101.38 Y117.82 E0.0063
Model is the 4C Adalinda by Loubie:
Adalinda.zip
(1.97 MiB) Downloaded 117 times
- extruders assigned as numbered.
So far, I haven't been able to work out why the crowning path is placed where it is and I have not found how to prevent it.
Any thoughts???
Thanks in advance
