running Kisslicer/Cubeitmod and trying out PLA. The fans are not running so the PLA gets a bit burnt. I see the fan g-gode is checked in Kisslicer.
Any ideas appriciated!
CubeX PLA fans not running?
Re: CubeX PLA fans not running?
Have you verified the fans are working?
Press "PJ-CONN" the fans should turn on.
Good call thanks!
They do work, but there is a Code 13 error present when I try the PJ-Con. Then the fans spin. So code 13..hmm..
Now PJ-Con colling fans turn on, but when I print PLA - no fans.
How much do you have for Fan Z [mm] into Matl table ?pingu wrote:Now PJ-Con colling fans turn on, but when I print PLA - no fans.
Under Printer / Firmware is Fan ON = M106 ?
Giovanni:
The mtrl settings are default. How should I change it?
Thanks.
Thanks.
Send some screen shots of your settings
pingu wrote:Giovanni:
Thanks.
The default is 200
Under Printer / Firmware is Fan ON = M106 ? Yes for me.
I have installed all of this fore the first time. I struggled with using 491 before i found this thread My first print with 6.05 the part fans did not run. The part is 12mm tall.
The default is 200
- Capture.PNG (28.18 KiB) Viewed 3414 times
moo00se wrote:How much do you have for Fan Z [mm] into Matl table ?
The default is 200
If you set "Fan Z = 0 " the fan will start from first layer, if you set FanZ =0.4 and you have 0.2 for layer thickness the fan will not work for the first 2 layers and after the fan will be turned on.
