Info Setting raft
alil2096
Info Setting raft
Hi, why when I activate the raft, if I have a layer of 0.2mm makes me a layer of 0.5mm raft ?
PeterSm
Re: Info Setting raft
Hello
Because layer height of first printed layer is "your layer height" + "z gap parameter in Support / Object interface setting" + "Printer/Hardware/Bed Roughness parameter"
For the second layer it is just "your layer height" + "z gap parameter in Support / Object interface setting"
If You do not want gap between raft and object, You have to set Z Gap to zero.
If You want to use raft and also support, well You'd have to find compromise between object/support gap and raft/object gap. Unfortunately it is controlled by one parameter.
Cheers
Cheers
Rebel 2 (reprap) 3d printer, Kisslicer 64bit v1.5 rc1, RepetierHost v1.6
alil2096
And sorry if i don't have answer before
