Found a way to get CubeitMod to work with newest Kisslicer!!
jonny.m
Post by jonny.m »
And here it is: CubeItMod5B5
Changes since last version:
Fixed a bug on the new Solid Speed reduction.
The speed change between normal Solid Speed and Short Solid Speed can now be adjusted.
Small Loops and Perimeters can be printed at lower Speeds. Only usefull if you have multiple small loops per layer.
I updated the description to show how the new features work, let me know if you have any comments on it. It also includes a "Initial Setup" to guide newbies through the first steps with Kisslicer and CubitMod.
Since CubeItMod becomes more and more complicated with things that might not always be neccessary I decided to work on a simpler, user friendly version which might be enough for most printing jobs. Hope to finish this one soon as well.
Regards,
Tobi
CubeItModV5B5.zip
(1.2 MiB) Downloaded 686 times
joestefano
Post by joestefano »
That sounds good, It is getting a bit complex for the average user. I'll give this version a try and get back to you. Thanks for all your hard work!
joestefano
Tobi, where is the 5B5 exe? it is not in the folder just the .po file
jonny.m
Post by jonny.m »
Hm, maybe your firewall or antivirus software ? Just tested it on two devices and the .exe is there. I attached it here again, renamed as .txt and zipped it with password protection (password: cubeitmod). Hope that works for you?
The folder I posted before contains two subfolders:
And this is the content of the two folders:
Is anyone else having this problem as well?
Regards,
Tobi
CubeItMod5B5.zip
(448.3 KiB) Downloaded 447 times
joestefano
Got it. it was my Norton blocking it, all set
