Nozzle stops for a bit after the 1st layer leaving a small b
When I print the 1st layer of almost any model, it looks okay but at the end of the 1st layer the print nozzle stops on top of model for a short while leaving a blob of PLA just before the other layers start printing. Is this to do with the keep warm setting?
KISSlicer v1.5 Beta 1.16 Win64
Pronterface, Printrun 2014/03/10 (github.com/kliment/Printrun)
Re: Nozzle stops for a bit after the 1st layer leaving a sma
Is your first layer temp lower than the main print temp?
No, I made the temp almost the same at the main temp to try and reduce the time it stops for now.
PLA
Main: 210
First Layer: 212
Keep-Warm: 210
Bed: 65
Any ideas would be great. I can't figure out why it stops after that 1st slow layer before it speeds up and prints beautifully.
PLA
Main: 210
First Layer: 212
Keep-Warm: 210
Bed: 65
Here is a bit of the code when it stops after the 1st layer and waits for some reason.
Maybe it has something to do with this line: [INFO] RECV: echo:Active Extruder: 0
[INFO] RECV: ok
[INFO] SENT: N243 G1 X93.92 Y90.74 E75.7566*108
[INFO] RECV: ok
[INFO] SENT: N244 G1 X89.49 Y96.37 E76.1799*96
[INFO] RECV: ok
[INFO] SENT: M105
[INFO] RECV: ok T:211.7 /212.0 B:65.6 /65.0 @:66 B@:0
[INFO] SENT: N245 G1 X89.98 Y95.19 E76.1799 F30000*55
[INFO] RECV: ok
[INFO] SENT: N246 G1 X92.95 Y91.42 E76.4632 F600*57
[INFO] RECV: ok
[INFO] SENT: N247 G1 X92.95 Y91.42 E76.4632 F30000*61
[INFO] RECV: ok
[INFO] SENT: N248 G1 E75.2132 F900*50
[INFO] RECV: ok
[INFO] SENT: M105
[INFO] RECV: ok T:211.7 /212.0 B:65.2 /65.0 @:63 B@:0
[INFO] SENT: N249 G1 X92.95 Y91.42 E75.2132 F600*52
[INFO] RECV: ok
[INFO] SENT: N250 G1 X89.98 Y95.19 E75.2132*97
[INFO] RECV: ok
[INFO] SENT: N251 G1 X89.98 Y95.19 Z0.7 E75.2132 F210*102
[INFO] RECV: ok
[INFO] SENT: N252 G92 E0*66
[INFO] RECV: ok
[INFO] SENT: N253 M104 S210*98
[INFO] RECV: ok
[INFO] SENT: N254 M542*35
[INFO] RECV: ok
[INFO] SENT: N255 M551 P32000 S900*43
[INFO] RECV: ok
[INFO] SENT: N256 M543*32
[INFO] RECV: ok
[INFO] SENT: N257 T0*58
[INFO] RECV: ok
[INFO] SENT: N258 M109 S210*100
[INFO] RECV: T:211.7 E:0 W:?
[INFO] RECV: T:212.0 E:0 W:?
[INFO] RECV: T:212.2 E:0 W:?
[INFO] RECV: T:212.5 E:0 W:?
[INFO] RECV: T:212.3 E:0 W:?
[INFO] RECV: T:211.8 E:0 W:?
[INFO] RECV: T:211.2 E:0 W:?
[INFO] RECV: T:210.8 E:0 W:9
[INFO] RECV: T:210.8 E:0 W:8
[INFO] RECV: T:210.0 E:0 W:7
[INFO] RECV: T:210.0 E:0 W:6
[INFO] RECV: T:209.8 E:0 W:5
[INFO] RECV: T:209.3 E:0 W:4
[INFO] RECV: T:209.3 E:0 W:3
[INFO] RECV: T:209.3 E:0 W:2
[INFO] RECV: T:209.3 E:0 W:1
[INFO] RECV: T:209.2 E:0 W:0
[INFO] RECV: ok
[INFO] SENT: M105
[INFO] RECV: ok T:209.2 /210.0 B:65.1 /65.0 @:67 B@:0
[INFO] SENT: M105
[INFO] SENT: M105
[INFO] SENT: M105
[INFO] SENT: M105
[INFO] SENT: M105
[INFO] SENT: M105
[INFO] SENT: M105
[INFO] RECV: ok T:209.2 /210.0 B:65.0 /65.0 @:65 B@:0
[INFO] SENT: M105
[INFO] SENT: N259 G92 E0*73
[INFO] RECV: ok
No, that means that the first extruder is active (computers like to start counting from 0).
But what cought my eye was this:There's a W parameter there that seems to count down until what seems like a stabilization period. That should be set on your printer firmware.
What printer and firmware is it?
It's a Japanese printer: Scoovo X9H. It runs Marlin 1.0.0 and has a RAMBo board. I can't change the firmware yet but after I hope I can. Can you see any way around this countdown problem?
I didn't get this problem in Slic3r so maybe there is something in Kisslicer that can help or some G-Code.
Well, if you know it works fine in Slic3r, you could replicate your settings there (first layer temp 2 degrees higher than the rest) and see what g-code comes out of it and then compare those two.
You propably also don't need those funky g-code commands during the extruder swap (first layer to second with temp change also counts as that): M542, M551 and M543. Marlin doesnt normally understand those.
I commented out everything from
Printer G-Code > Select Extruder
and
Printer G-Code > Deselect Extruder
with semi-colons and maybe everything is good now.
Thank you very much for the advice Mikk36.
and
- plexus
- Site Admin
Hi there. welcome to the forum. if you post an issue/problem and it gets solved, consider editing the subject of your post to include [SOLVED] so people know that the thread includes a solution to the posted problem.
