I'm trying to write a post processor and can't get it to work (1.5 beta2) on either OS X or Windows 8. I've distilled it down to a trivial script and it fails with this message: "Failed, returning 512". The error dialog that pops up shows the correct path to my python script and the gcode file path.
It fails in the same way on version 1.4.1.12.
I can run the script from the command line with no problems. There must be some config or permissions problem. What is the 512 error code?
Post Processor failure...
- mhackney
- mhackney
Re: Post Processor failure...
You know, I've been struggling with this problem for a couple of days. I just running my script from the command line and realized it is executed as pythonw /....../scriptname.py "<FILE>"
Doh! need to include the interpreter in the post processor command line. It works fine now.
