Terrible seams
Miatpi
Re: Terrible seams
Post by Miatpi »
Hmmm, so I don't have to ask the whole day what to increase/decrease:
What should I icrease/decrease if:
1. If my print is hairy.
2. If the seams are bad and have holes.
3. If there are blobs at the start/end of a seam.
Thank you so much for helping! :D
Hugues
Re: Terrible seams
Post by Hugues »
For PLA i use this setup, maybe it can help you :
M227P : 0.06
M227S : 0.15
M228P : 0.0001
M228S : 1.3
Seam Depht :0.6
Seam Gap : 0.4
And i check the box "loops goes inside to perimeter"
regards,
Hugues
www.cubexupgrade.com
Hugues
Re: Terrible seams
Post by Hugues »
Sorry but with ABS i've no set my printer. It's harder to get a good print due to the material proprieties. And the setup i give you is for my 0.3 nozzle, not the stock one.
To setup this i use 3 cylinders with different diameters (10mm/5mm/2mm) on one file with different space between them. Play with those values to get a good balance but with the stock extruder i never get print without hairy stuff.
regards,
Hugues
Miatpi
Re: Terrible seams
Post by Miatpi »
But to avoid hairyness, is it the M228 S (Speed) I have have to increase?
Hugues
Re: Terrible seams
Post by Hugues »
You can try but after 1.5 on this value i get some bug print.
regards,
Hugues
Miatpi
Re: Terrible seams
Post by Miatpi »
Your'e so kind answering all my questions. If it would be for you it would have taken a long time sorting these things out.
But the seam problem remains. I still can't send a pic of it, but I can try to describe it:
Basically when the orinter should print a seam, instead of printing a line it's printing some dots on where the line should be. But it only happen on those two thin shapes.
I upload a sketch there I try to describe it.
Hugues
Re: Terrible seams
Post by Hugues »
How do you test you seam setup ?
I just open your file and they are not really printable ! there is lot of error on it.
Setup your seam with simple shapes !
regards,
Hugues
Miatpi
Re: Terrible seams
Post by Miatpi »
Well, at least the model works fine for me.
What does the gap and depth really do, I can't find any explenation for them.
When I looked at my model I realised a thing with the two antenns (that print incorectly). I have beveled its edges, so there are an inside and outside surface thats wery close to eachother.
May this be whats messing things up?
Hugues
Re: Terrible seams
Post by Hugues »
All shapes are open, true you can slice them but result may be weird. Close them all.
Gap and Depth are use to change the "seam space". Open a simple and close cylinder slice it and play with them, zoom on the seam to see how they move the path.
regards,
Hugues
Miatpi
Re: Terrible seams
Post by Miatpi »
I finally got a picture of the problem!
As you see the surface is generally a little bumpy, and when it comes to the eyes... :shock: :shock: :shock: ... it doesn't look that good.
I'm sure it doesn't depend on the model since the most of the printing is very accurate.
2015-01-21 13.49.34.jpg (155.66 KiB) Viewed 3899 times
