I love kisslicer and also love klipper.
But it is not possible to use preload nad LA at the same time. I've read some posts it is possible but from klipper github:
https://github.com/KevinOConnor/klipper/issues/1423
https://github.com/KevinOConnor/klipper/issues/1172
It is not problem to disable preload (set to 0) but some mistakes on model (changing speeds at overhang) still exists.you shouldn't use kisslicer's preloadVE on Klipper. preloadVE try to pressurized the nozzle by extruding a lot during the start of a print. klipper doesn't like a slicer manipulating the extrusion like that. the best bet is just diasble preloadVE and use Klipper's pressure advance.
I should say, you shouldn't use kisslicer on klipper at all. the reason being kisslicer will generate code that slowdown the print speed during overhang and klipper doesn't like speed transition at all, it will result in a micro pause during the transition and again when it transits from slow to fast.
Do you have any experiences with this?
Or how to successfully use kisslicer with klipper?
