Control the origin of parts and auto-centering.
Marc
Post by Marc »
I use kisslicer, it's a great softwear, thank you creator!
But I've a little problem :
I print on special support or parts, whit muti-materials and process, on different machines.
That is why, I need I need of mastering the origin of parts.
I use Rhino for modeling STL, I can save the origine in the file.
But in kisslicer, the parte is "centered".
I test disable the auto-rotating option, inefficacious.
I test with smals part in corners, inefficacious (the centering is not always the same...).
For informations, this problem has already been mentioned here : https://groups.google.com/forum/#!searc ... VknJUaDosJ
Thanks!
