Adding .ini setup files for Kisslicer
OneLooseCrank
Post by OneLooseCrank »
Hi all,
I've requested this in the BFB3000 forum but I think it's a very quiet spot, so I'm doubling up the question here. I have downloaded some .ini files from that forum to set try a print as I've having a layer shift issue that might be software, not hardware related. Can anyone tell me how to add the .ini files to Kisslicer?
Cheers,
OLC
marius
Re: Adding .ini setup files for Kisslicer
Post by marius »
if the .ini files are named as the original .ini files, such as _printers.ini, _supports.ini, _styles.ini or _materials.ini, just replace the ones you already have alongside the kisslicer executable, or copy the executable into a folder where those files are. Kisslicer should recognise the .ini files, if they are structured correctly, and load them.
regards
M
