Prusa "original" Mk3 Profiles (single filament)
Postby pjr » 01 Apr 2018, 07:39
Hi Guys
Having just received and build my Mk3, I have now added profiles to my FTP site. Downloads are available from this page: http://www.kisslicer.com/preconfigured-profiles.html (is currently does not mention the Mk3, but they are there...).
The profiles are set up for Printer, PLA (including Preload and Linear Advance - both set for PR filament), and a variety of styles (including variable layer height) and support. These were generated using firmware 3.2.0 alpha where LA has been re-enabled.
If you have any problems, please let me know.
As soon as the MMU V2 arrives, I will have a look at setting up profiles for that as well.
Re: Prusa "original" Mk3 Profiles (single filament)
Postby pjr » 02 Apr 2018, 15:17
FWIW, quick note regarding Linear Advance in firmware 3.2.0 alpha:
Seems that using both Preload and LA has issues. Skipping at start of sector, so it seems to be overloading the extruder or missing steps.
Printing via OctoPrint; sending "M900 K0" during a print immediately stops the extruder skipping.
My feeling is that LA may not be respecting the firmware limits, but I am probably very wrong...
Return to General
