PrusaPP
Re: PrusaPP
Postby pjr » 27 Oct 2017, 01:55
qwalker wrote:Are there any differences between your post processor and the PRO version? I just started using KISSlicer and I want to continue after I upgrade
Hi Quentin
The KISS PRO license allows you to slice with multiple extruders (and use many more features within KISS). The Post Processor is a free program which (simplistically) will take the output from KISS and add a purge tower.
The post processor will do nothing unless you have the KISS PRO license and have sliced the model with multiple extruders.
Re: PrusaPP
Postby pjr » 06 Nov 2017, 13:15
Latest post-processor version is now on-line:
V1.5 Beta 4
FIX: Amended tower perimeters to bond better and increase the used preload value.
FIX: Reduce unload/load distance by 5mm to better match the latest PR firmware filament loading.
Re: PrusaPP
Postby BeNe » 13 Nov 2017, 15:34
The new Version works just fine 8-)
Thank you, Peter.
Is there a way to add support for print one after one (sequential) with your PostProcessor ?
It doesn´t create the waste tower correct.
BeNe
Re: PrusaPP
Postby pjr » 13 Nov 2017, 16:01
BeNe wrote:Is there a way to add support for print one after one (sequential) with your PostProcessor ?
No, sorry, doesn't support sequential model printing. Never been a fan of that method... Tried it once and nearly broke the printer (bent the heat break).
Previous
Return to Post-processors
