Kisslicer Pro - IDEX
Posted: 08 Feb 2019, 17:22
by olo2000pm
Hey.
I built IDEX type printer.
Can you share the start code?
I do not know how to make it work properly in ditto mode.
I have a duet wifi and duex
Re: Kisslicer Pro - IDEX
Posted: 11 Feb 2019, 06:26
by olo2000pm
I have electronics duet WiFi and duex. Nobody knows how to initiate a print in ditto mode?
Posted: 11 Feb 2019, 10:26
olo2000pm wrote:Nobody knows how to initiate a print in ditto mode?
Very unlikely that is the case. However I certainly don't but I am guessing it would not be too difficult to get it set up...
Have you printed anything at all on this printer? Do you have any files already sliced? If so, you could post one here and I will take a look.
Posted: 12 Feb 2019, 05:37
by olo2000pm
Posted: 12 Feb 2019, 05:58
Brilliant.
Now you can share
Posted: 12 Feb 2019, 13:55
by olo2000pm
I created the third head.
I open the file and click on it and choose the third head.
prefix:
; [mm] tryb
G21
G90
M82
G28
T0
M140 S <BED>
M116
M104 S <TEMP>
M116
T1
M106
T <EXT + 0>
M109 S <TEMP>
M104 S <TEMP>
T2
The rest I'm doing is the duet wifi software.
Posted: 08 Mar 2019, 02:23
by olo2000pm
It does not work well. When I want to print from ABS and PVA, is T0 setting me 205'C instead of 245? I have defined heads in EXT MAP. What needs to be changed?
Posted: 08 Mar 2019, 09:16
olo2000pm wrote:It does not work well. When I want to print from ABS and PVA, is T0 setting me 205'C instead of 245? I have defined heads in EXT MAP. What needs to be changed?
Please look at Settings/Printer G-code/Select New Ext & Warm
There should be something like this:
Posted: 03 Jun 2019, 15:10
by Pocohanthes
I tried same procedure posted here but it doesn't work. I might be doing something wrongly though.
