Sorry for my late reply. I saw it only now. Yes, generally speaking I'd like to have better control over the final position of the object on the plate. If I model the plate accurately on the CAD system and then place the object in the right position for my printer, I'd like the Kisslicer to keep it there. I like the possibility to specify a new position for the origin or, as you say, (0,0) which should mean leave it as it is.
@Peter: The STL has the coordinates relative to the origin of axis you specified in the CAD model. So to achieve my task I just need to have the coordinate system in the correct spot.
Is it possible to access the new beta version?
Massimiliano
lonesock wrote:Is this a case where you are only loading a single model, and only want to print a single instance of it? If so, I could hijack the bed position sliders to place it (at least close to) where it would have been in your CAD system. If you have multiple objects or multiple instances of the same object, this wouldn't work.
The new beta has the ability to specify the XY location exactly on the command line, which would work for you (use 0,0), but that seems a bit awkward.
