CubeItMod V 6.0 New Version !!!
Re: CubeItMod V 6.0 New Version !!!
Mimban wrote: My last setting is 20% infill, Solid & Support speed 20, Sparse ifill speed 30 at precise pane. This seems to be ok no clogging.
I'm talking about "Infill%" into Matl tab, this value must be close to 100.
If you're talking about "ShortInfill%" into "Printer G-code" -> "Prefix" tab, 20 is OK.
Mimban wrote: The extruder voltege is 1.48 - i have no patience to - and the chip has a piece of aluminium as a cooler.
You can push the voltage to 1.6V, this will reduce the clicking.
Mimban
Post by Mimban »
Oh, sorry. The infill on that tab is 100%. May i set to lower? This was the default setting.
100% is OK
marioroberto
Post by marioroberto »
Finally, it worked. Thanks a lot Giovanni. Now I'm going to start playing with settings and stuff. ¿Is there a problem if I want to print primalloy on a Cubex?
Thanks again.
Giovanni V. wrote:
marioroberto wrote:Hi Giovani, I used the ones that came with the download, but there was no Cubex printer, so I change them to the old ini files that I had. Here's the bak file http://www.clinicaedentalgroup.com/imag ... 29.bfb.bak
Copy the printer.ini file that comes with Cubeitmod605 into KS folder, the Cubex printer is present, into this file there are some parameters that are absolutely necessary to make Cubeitmod work.
marioroberto wrote:Finally, it worked. Thanks a lot Giovanni. Now I'm going to start playing with settings and stuff. ¿Is there a problem if I want to print primalloy on a Cubex?
Thanks again.
Primalloy has 33 Shore D hardness, I've successfully printed harder elastomers with 65 Shore D hardmess, I cannot tell you if you can print this one or not, but if you try let us know, it's very interesting.
marioroberto
Hi there. I printed a decent model and I started to change settings, and now it's all blurry and confusing. ¿Do you have like a satandard configuration for PLA printings¿ Thank you!
gastonfama
Post by gastonfama »
marioroberto wrote:Hi there. I printed a decent model and I started to change settings, and now it's all blurry and confusing. ¿Do you have like a satandard configuration for PLA printings¿ Thank you!
If you open the .bak file, you can find all the configuration parameters... you can turn it back using that info.
Kisslicer can play you tricks with its auto save function, always copy the parameters before changing and testing.
Regards.
marioroberto
Thanks!
Alertpos
Post by Alertpos »
Do you have the .ini files for cubeitmod605? Or at least the g-codes? I am getting a line 16 error when I try to run the .bfb file on my CubeX duo. I think I messed up the g-codes. Here are the first few lines of a file that is giving me the error:
^Firmware:V1.07
G21
G90
M542
M204 S220
M227 P592 S118
M228 P16 S379
M552 P700 S80
M543
M106 S255
M103
M208 S65
G1 X-115.21 Y-34.54 Z0.6 F4800
G1 X-115.21 Y-34.54 Z0.35 F150
M201
M208 S-1.#IND <---- This is line 16 that is showing an error on my CubeX due v1.07 firmware.
G1 X-114.86 Y-34.74 Z0.35 F4200
M208 S-1.#IND
G1 X-114.37 Y-34.8 Z0.35 F4200
M208 S-1.#IND
G1 X-113.54 Y-34.79 Z0.35 F4200
M208 S-1.#IND
G1 X-115.47 Y-32.86 Z0.35 F4200
M208 S-1.#IND
G1 X-115.46 Y-31.45 Z0.35 F4200
ini files for 6.05 are into the same zip file with the cubeitmod605.exe file.
Alertpos wrote:Do you have the .ini files for cubeitmod605? Or at least the g-codes? I am getting a line 16 error when I try to run the .bfb file on my CubeX duo. I think I messed up the g-codes. Here are the first few lines of a file that is giving me the error:
^Firmware:V1.07
G21
G90
M542
M204 S220
M227 P592 S118
M228 P16 S379
M552 P700 S80
M543
M106 S255
M103
M208 S65
M201
M208 S-1.#IND
M208 S-1.#IND
M208 S-1.#IND
M208 S-1.#IND
