CubeX printing problem
rantzaus
Post by rantzaus »
Hey Out there
I have had my cubex's for a good time now. Made the GRM Z-stopper mod and installed a cubstom One hotend.
But the last weeks I have got really bad prints.
It looks like the perimeters are not touching each other and the solid top got some holes.
I have uploaded the .bfb .bak and my setting on my dropbox, link to folder:
https://www.dropbox.com/sh/02n79aszj40i ... q6zfa?dl=0
Someone please help?
Re: CubeX printing problem
looks like the flow is too low, you have holes one the sides and on the top.
Check the diameter of your filament, run a cylinder print with single loop and infill = vase then measure the thickness of the wall.
How much is the flow tweak ?
Did you increase the voltage on the extruder ?
rantzaus
Post by rantzaus »
Hi Giovanni
I made a flow tweak adjustment print using the finetune.stl
Walls are 0.4-ish
Flowtweak is 1 and no voltage increase on the extruder.
rantzaus wrote:Hi Giovanni
Walls are 0.4-ish
I think you shoud increase the voltage and put a sink on the driver chip.
