Gauging interest: CubeXY
gastonfama
Re: Gauging interest: CubeXY
Post by gastonfama »
Giovanni V. wrote: I had problems with my Cubex motherboard and as I don't want to give more money to 3DSystems I've decided to go for RepRap.
I've installed a Rumba with DRV8525 drivers and Marlin firmware.
I understand you...
Good luck with the opens source, and thank you for all the great work with CubeitMod...
Regards.
obelisk79
Post by obelisk79 »
Just an update: I'm well along on my conversion, I've taken my time as I have a busy home and work life. right now I've done the basic reprap conversion and am calibrating firmware. After this is complete and I have reliable dimensional accuracy I'll start printing the new y-axis linear guides, stepper mounts and x carriage for the final transition to CoreXY. I have everything ready to finish this but the printed parts.
I'll post a coherent build log once I've got everything mostly functioning. Unfortunately I've not taken nearly as many pictures as I had originally intended. If the conversion goes well however, I may purchase a second CubeX to convert as well where I can document the process better.
gastonfama
Gooooood
What are your expectations regarding this conversion? What do you suppose that will be improved? Are you planing to change the extruders too?
Regards.
obelisk79
Post by obelisk79 »
I hope to improve the following
Print quality
Easier calibration and tuning
Print speed
Learn new things
I have moved the extruder off of the x carriage and am using a Bowden tube setup. I think that will only be temporary however.
obelisk79
Post by obelisk79 »
My setup looks so much more sketchy, but all electrical connections are sound with clean solder joints and heat shrink. Finally started a test print off 3d benchy hope it measures out well. I haven't really tweaked the calibration yet. I'll be using it in this configuration to print the parts for the CoreXY conversion to finish the mod.
http://sendvid.com/ba4rhmsv <--- short video of it in action. I noticed an immediate and notable improvement in print quality with my normal calibration object. This is the benchy print in its early layers.
pingu
Post by pingu »
A follow up on this would be great!
This is a video of my Cubex Duo converted to RepRap :
https://youtu.be/lCmuWdlxsWY
