Cubex Print issue
Cubex Print issue
Postby natholego11 » 09 Mar 2018, 10:41
Hello All,
I am fairly new to the 3d printing world, at least in owning my own, I have worked on and with projet's, objet's, and the like for many years. but I came across a pretty good deal on a brand new unopened cubex. so I have had it now for about 8 months and have been having moderate success with it. but have been really trying to get the settings tuned in.
so I ran the calibration wall and they looked... ok I guess, but shortly afterwards I ran the calibration cube, twice (and by twice I mean I ran it once, took it off and ran the exact same print again. not I ran the same model twice on the same print)
here were the results:
As you can see there is one part that consistently doesn't turn out well. so I left it for a few weeks and didn't try anything, then I printed a decently large cylinder for another project and had similar results.
Then last night I printed some dies for my Bead roller before I machine the right ones. and here is how they turned out. again there is this consistent "lack" of material in the same movement on the X and Y axis. it occurs both inside and outside the part:
Has anybody else seen this before?
any thoughts on what it might be?
natholego11
Re: Cubex Print issue
Postby rantzaus » 13 Mar 2018, 05:26
Hey there and welcome
Have you done any modification on your printer?
Is everything still from stock?
I looks like you have problems with your flow. Have you tuned in your M227 and M228 settings?
These are your prime and suck setting when finishing and starting a path.
What temperatures are you printing at?
I have done a lot of modifications on mine 2 cubeX and they are printing fairly OK and constant.
rantzaus
Postby natholego11 » 25 Mar 2018, 18:00
The only things I have done to the printer were to add a rip-rap heater to the build platform, which I need to redo because it doesnt fully heat the build area.
and I enclosed the printer with plexiglass and added a door to the front. other than that the printer is completely stock from the factory.
as far as all the settings go please check out the file I attached it has screenshots of all the settings I have used for this print.
Archive.zip
all kisslicer settings
(310.56 KiB) Downloaded 71 times
natholego11
Postby natholego11 » 04 Apr 2018, 18:37
any thoughts on this issue?
natholego11
Postby Giovanni V. » 05 Apr 2018, 14:56
natholego11 wrote:any thoughts on this issue?
looks like a M227, 228 issue.
first try to set M228S = 0
if it's better but not enough you have to reduce the other parameters M227 & 228.
Look into the old posts ( here on this forum or into the Goolge's goups, Cubex or Kisslicer group ) I've described how these parameters works.
Postby natholego11 » 16 Apr 2018, 20:05
Looking for that value, but I dont see anywhere that says M228S or M228P anywhere in Kisslicer, where is this value you are talking about?
natholego11
Postby Giovanni V. » 17 Apr 2018, 13:24
The attachment Capture.PNG is no longer available
This is the screen shot you've previously sent.
Screen Shot 2018-03-23 at 12.07.34 PM.png (45.71 KiB) Viewed 1329 times
To change the names into the menu you have to load the language file Cubeitmod.po
Postby natholego11 » 18 Apr 2018, 05:58
Ok, so I tried a print with M227S at 0 that helped but not enough, so I changed M227P to 0 and that made it worse. Here are the results from that print:
natholego11
Postby Giovanni V. » 18 Apr 2018, 14:46
The last pictures you sent show at least 2 different problems.
1 - seam problem related to M227 M228 parameters
2 - some layers are weak, you have to solve this problem before the seam problem.
Look this :
viewtopic.php?f=20&t=1262&p=3413&hilit=heat+sink#p3395
read the document into the Motor.zip file and check the diameter of your filament.
Use standard parameters like those :
M227P =0.06
M227S=0.02
M228P=0.0
M228S=0.01
After you solved the problem and your printer can print all the layers the same you can refine the seam parameters.
Postby natholego11 » 03 May 2018, 09:08
Giovanni V. wrote:The last pictures you sent show at least 2 different problems.
Look this :
M227P =0.06
M227S=0.02
M228P=0.0
M228S=0.01
well, I started to do this work, and fried the motherboard. so there goes that printer.
Thanks for the help though, It was a good run!
natholego11
Next
Return to 3D Systems: Cubex, Cubepro etc.
