Is the circular infill pattern the same as the octagon?
K.Miya
Post by K.Miya »
Hellow!
I was looking at each infill pattern, but I couldn't find the difference between the circular infill pattern and the octagonal infill pattern.
There is a possibility of the same process.
K.Miya
Re: Is the circular infill pattern the same as the octagon?
Post by K.Miya »
I'm sorry, the Circular infill pattern is a rounded infill pattern.
I have never been able to tell the difference either, but I think it depends on the type of printer in use and whether that printer is able to use the G2 command.
K.Miya
Post by K.Miya »
Thank you Peter
It seems that the pattern I used was too small to make a difference.
It is not reflected in the path view.
K.Miya
