Graphic doesn't show internal travel/jump moves.
calinb
Post by calinb »
In trying to see the differences between [Style >> Travel >> Stay Inside] and [Style >> Travel >> Avoid Edge] gcode, I noticed that none of the Kisslicer graphics are displaying jumps above the bottom of this box in any of the viewing modes (Models+Paths or Paths with Extruder, Path Type, and with or without "3D" check, etc.) . However, Rep-Host shows the jumps:
BTW, can anyone tell me what differences I should expect to see between the "Stay Inside" and Avoid Edges" settings? The paths ARE different, but I don't see a substantive difference--even when I can see the jump differences in Rep-Host. The results are about the same--with or without seams on corners on this model (and others).
This is 2a 0.6.5 Win64.
Thanks!
KISSlicer user since 2012 (PRO since 2013)!
calinb
Re: Graphic doesn't show internal travel/jump moves.
Post by calinb »
This path rendering bug still exists in both 1.6.3 and V2-alpha. However, it's possible to see true jump paths by using Rep-Host to examine Kisslicer gcode.
