V1.6.2 Win64
No matter if variable or fixed layer height is used:
First Layer Thickness ignored
- Kisslicer_1stLayerHeightBug_varHeight.png (68.68 KiB) Viewed 1296 times
- Kisslicer_1stLayerHeightBug_fixedHeight.png (78.97 KiB) Viewed 1296 times
- plm
Re: First Layer Thickness ignored
What is set in Printer - Hardware - Z Step [mm]?
Z step is set to 0
(sorry for late response, forgot that notify-me-tick)
Set it to 0.05 and that indeed changed the 1st layer. Unfortunately, first layer height is overriden depending on values of Layer Thickness / Max (and model geometry if these values are not equal). As a user I expect the first layer to be whatever I defined in 1st - regardless of thickness, max, z step or geometry. Everything else is confusing and removal of the property should be considered.
