Hi
In KS 1.5 RealeseIf you use grid + (large) brim option with multiple objects/Island, islands grids cross themselves : the grid do not take in account the brim diameter.
To avoid : use "Inflate Raft..." option to correct...but you will see your prime pillar growing as well
Regards
...is there anybody (Jonathan) out there?
Grid do not take in account the brim diameter
- Olivier13
http://www.additec.fr
Re: Grid do not take in account the brim diameter
Hi
I have just checked the latest alpha and it does not appear to be an issue in that.
I loaded 2 models, set brim to 10mm and inflate raft to 3mm. After slicing the raft looks just a little more than 3mm outside the brim.
You may want to check it out when the next beta arrives.
