Hey, I ran across one of my first bugs with v1.4.5
I sliced up this big bowl thing (random print for a friend) and in v1.1.0.14 everything looks great, but in v1.4.5 I get this odd patter on the bottom, which I cant have for a friends print. It also translates into the upper post-infill layers. For the record Slic3r does not do it, but I hate using that program, mainly because of the inside diameter of holes/interlocking parts...
Virtually exact same settings between the two different versions. I would upload the STL, but after adding supports with MeshMixer, the file ends up being 300mb. I can upload to Google Drive if someone wants to take a look.
Let me know what you want/need from me.
Thanks,
James
Odd artifacts on v1.4.5
Re: Odd artifacts on v1.4.5
Please use version 1.5.20 or 1.5.20 instead.
There placed in the dropbox folder.
Is the stl getting error flagged before you slice?
Yep..... Thanks....
I tried to run it though netfabb, but no success.
It is odd that it doesn't do it on the older version though, right? and only for the first layer?
- Shell - v1.5.b20-model errors.png (82.76 KiB) Viewed 2372 times
I just posted Windows builds for a new version, 1.5 beta 3.4 into the Dropbox folder. (I'm really hoping no show-stopping bugs are found!) Could you test it out for me?
(P.S. I'm working on getting Linux builds up, Mac will take another few days.)
