Print "dots" and other tiny features last
626Pilot
Post by 626Pilot »
If you are printing something with tiny features - for example, the number 3, where it has to draw little "dots" to fill in the space inside the number - KISSlicer, for some reason, draws these first, before any loops. If it waited until it was done drawing the loops, they would be there to help catch onto the "dots" and keep them from lifting off the glass. Because it doesn't do this, getting a 1st layer with this kind of feature can require over an hour of tweaking every last setting, adjusting the Z-height by microns, etc.
The logic would be easy. If the path length is less than a few millimeters, do it last!!!
