Hi. In my quest for a clear part, i do a lot of test with all slicer. And I found better result with concentric infill. If you can add this function in one of your next uprgrade this ll be fine.
Have a nice day.
Morgan
Concentric infill
Re: Concentric infill
I found a way to cheating. You can give a huge " Num Loops " which will give the same result as a full concentric infill.
- Davide Ardizzoia
I don't think that using huge number of loops will serve you well, unless you have found a supplier for free filament
To get nice upper face finish there is just one way: careful and precise material setting (diameter) and slow speed.
Best Regards
Best Regards
There's also a bug in high loop numbers, Jonathan is aware of, that the start points jump around causing the nozzle to drag across loops.
It s not for the upper face, it s for the infill. With an high number of loop we get great result and great transparency. At 60 mm/s
