too many print speed - delta printer BIQU Magician
BM-KISS-PB
Post by BM-KISS-PB »
Hello all
I have recently used the BIQU Magician delta.
I like the KISSLICER slicer for its parameter setting possibilities, but there is one problem with the print speed.
I am using the KISSLICER 1.6.3 64 bit version and no matter how I set the print speed, the printer prints at about 100 mm / s, which is too much for this printer.
I set the speed range in the SPEED tab from about 10 to 30 mm / s and the printer still prints with a speed of about 100 mm / s.
I moved the precision slider to different positions from min to max and the printing speed did not change anyway.
The printer has been configured according to the wizard, I am using the EXPERT level.
If anyone had similar problems, please help.
best regards
PB
ksh_germany
Re: too many print speed - delta printer BIQU Magician
Post by ksh_germany »
too less informations, please send Printer settings. i think you set the firmware type wrong
