Why is this happening?
Posted: 04 Apr 2020, 05:54
by Cameluntu
A word is worth a thousand words.
Why am i getting this?Or at least what should i check? I have looked everywhere, seam is in the middle section. I have tried preload = to 6 and = to 0.75 (for science) and i get similar results.
- photo5782835476363850036.jpg (119.7 KiB) Viewed 700 times
- photo5782835476363850037.jpg (81.03 KiB) Viewed 700 times
Thank you in advance for any help!!!
Re: Why is this happening?
Posted: 04 Apr 2020, 10:29
by ksh_germany
Hello,
i think it will come from wipe or Unload Setting you're using alpha 1.6.3?
because there is an issue with unload Settings, take a look
viewtopic.php?f=5&t=4744&start=10#p10602
Posted: 06 Apr 2020, 02:50
by Cameluntu
Thanks for your reply! However i have tried disabling unload and wipe, results are similar. I'll download v1 and see if i get the same issue.
Posted: 06 Apr 2020, 09:36
by ksh_germany
Please send gcode, for Research.
Posted: 06 Apr 2020, 10:17
by Cameluntu
This is the very last one with unload set to 50mm, i would need to print another one without unload if you want to dive into it.
Posted: 07 Apr 2020, 08:10
by Cameluntu
i think i found the issue comparing my different printers. PreloadVE and Linear Advance dont like each other (probably for obvious reasons), disabling PVE would not generate the issues above.
Posted: 07 Apr 2020, 13:34
by Cameluntu
Apparently it's not even that, so gl kisslicer and welcome prusa slicer . Cheers
Posted: 07 Apr 2020, 13:35
by ksh_germany
nice to know thanks for telling your experience
