Re: The Tip Is Not Printed
Posted: 02 Oct 2019, 09:13
by ksh_germany
Hi, have you tired to Set the oversample Resolution small er? (pro/Premium Feature) when you share the stl i can Try to find a solution.
Posted: 02 Oct 2019, 10:52
by ksh_germany
So i tested, the only way i found is to layer that small unicorn on side. So horn will be printed.
i testet a slice with a 0.2 nozzle even there the tip wan't to be printed. Scaling changes nothing!
Posted: 03 Oct 2019, 02:42
by ksh_germany
Yes yes you have to put IT on the side so tip will printed.
Or you put an 0.1 nozzle in your hotend.
