Dual extrusion setup
Tinchus2009
Post by Tinchus2009 »
Hi, Im trying to setup the dual extrusion print. I have configured my printer profile, material profiles, I think my hotends ffsets are good. But Im haveing some troubles with ooozing mainly.
Can some PRO share your gcode scripts located in the priner gcode section (warms up, extruder changes, cooling, et) SI I can learn and may be usein them?
Also any ti you have about dual config will be welcome
Thanks in advance
ImpulsiveJames
Re: Dual extrusion setup
Post by ImpulsiveJames »
A simple solution would be to use the Wall prime structure and get it pretty close to the model, about 1mm or so away. Otherwise you have to really tune the temps and I just use G1 X5 for every warm up cycle.
James
