ZGap won't work
Acmeman76
ZGap won't work
Post by Acmeman76 »
Hi all
i've an issue with KIssslicer 1.6.3: i can't setting up the zgap trough the gcode generation, as you can see in the image i've set zgap 0.2 but no space in the 3d model neither in 2d.
What's wrong?
Greetings
Re: ZGap won't work
So, the support layer heights are adjusted during export and not visible in the views after slicing.
When the G-code is exported, the Z-gap is present and is a value between 0 and 90% of current layer height (adaptive layers).
sinned6915
Re: ZGap won't work
Post by sinned6915 »
is the value for Zgap in % or absolute millimters?
what is the difference between the settings for "1st Zgap" and "Zgap". where might there be a Zgap that is not 1st?
tia
dennis
Re: ZGap won't work
1st Z-gap is for the raft; Z-gap is for the support interface
woody3dp
Re: ZGap won't work
Post by woody3dp »
pjr wrote:So, the support layer heights are adjusted during export and not visible in the views after slicing.
- Does it work the same way for fixed layer (I often print with fixed layer for the moment) ?
- Is there a way to bypass this value, because my support fuses to my object, it's very difficult to remove the support without damaging the object.
thanks
Re: ZGap won't work
woody3dp wrote: - Does it work the same way for fixed layer (I often print with fixed layer for the moment) ?
thanks
This has been added to the fault list:
Z-gap. Must be according to set value irrespective of layer height and must be able to be viewed after slicing.
woody3dp
Re: ZGap won't work
Post by woody3dp »
That's a good new. Thank you for taking your time to answer Peter.
