Hi folks,
Occasionally Kisslicer after I've done a slice will display the 3D model as well as the generated
supports. The problem is I don't know how to get it to do this all the time or what I did.
I would like to say that I've done everything to get this work but obviously I haven't.
What am I missing here?
Help appreciated.
how to get Kisslicer to display model and supports
- EddyMI3D
Re: how to get Kisslicer to display model and supports
Usually Kisslicer save the last settings you made.
Try to start as admin, maybe you have restrictions the place where Kisslicer runs.
When the preview mode is "Models+Paths", if the Z slider (just to the right of the model preview) is all the way at the bottom, and if the model is already sliced, KISSlicer will display all layers' paths at the same time. I wonder if this is the behavior you were seeing? (Note: If you are in "Models_Paths" view already, and you slice the model, it will default to this view as soon as the paths are generated.)
