The Tip Is Not Printed
Postby deepwhite » 01 Oct 2019, 16:51
hi there,
i designed a "baby unicorn" model early on, and was trying to print it with kisslicer today, only to find that the tip of the horn (corn?) is left out after the slicing. please find the screenshot in the attachment.
people told me that it was because the tip was smaller than the printing head (0.4mm), and there is no way around it with kisslicer, but to use other slicing softwares. yet i don't want to give up. please be so kind as to help me out here with this issue, thanks.
best regards,
arys chien
deepwhite studio
Screen Shot 2019-10-01 at 9.50.51 PM.png (86.07 KiB) Viewed 216 times
deepwhite
Re: The Tip Is Not Printed
Postby ksh_germany » 02 Oct 2019, 09:13
Hi, have you tired to Set the oversample Resolution small er? (pro/Premium Feature) when you share the stl i can Try to find a solution.
Greetings from Germany
Beantworte fragen zu Kisslicer auf deutsch ;)
ksh_germany
Postby deepwhite » 02 Oct 2019, 09:19
ksh_germany wrote:Hi, have you tired to Set the oversample Resolution small er? (pro/Premium Feature) when you share the stl i can Try to find a solution.
thanks for the tip. i'll give it a try. kisslicer is a great software and worth paying for a pro version.
the stl file is here: https://www.myminifactory.com/object/3d ... hite-86239
deepwhite
Postby ksh_germany » 02 Oct 2019, 10:52
So i tested, the only way i found is to layer that small unicorn on side. So horn will be printed.
i testet a slice with a 0.2 nozzle even there the tip wan't to be printed. Scaling changes nothing!
ksh_germany
Postby deepwhite » 02 Oct 2019, 20:35
tried it. "oversample resolution" doesn't help, even when set to very small value (like 0.02mm) :|
deepwhite
Postby ksh_germany » 03 Oct 2019, 02:42
Yes yes you have to put IT on the side so tip will printed.
Or you put an 0.1 nozzle in your hotend.
ksh_germany
Return to Troubleshooting
