Feature "miniretracts" ?
Postby derdigge » 04 Nov 2018, 14:11
Dear all.
What kind of feature is this:
; 'Loop Path', 1.2 [feed mm/s], 20.0 [head mm/s]
G1 X158.551 Y158.582 E0 F12000
; head speed 19.999998, filament speed 1.193662, preload 0.893814
G1 X158.5 Y158.582 E0.28062 F204.1
G1 X158.464 Y158.582 E0.08807 F469.8
G1 X158.396 Y158.582 E0.11947 F613.3
G1 X158.308 Y158.582 E0.1131 F770.5
G1 X158.201 Y158.582 E0.10253 F912.2
G1 X158.075 Y158.582 E0.08683 F1032.6
G1 X157.929 Y158.582 E0.06509 F1124.8
G1 X157.764 Y158.582 E0.03636 F1180.8
G1 X157.58 Y158.582 E0.01206 F1199.3
G1 X157.376 Y158.582 E0.01217 F1200
G1 X141.418 Y158.582 E0.95244
G1 X141.418 Y141.418 E1.02445
G1 X158.582 Y141.418 E1.02445
G1 X158.582 Y157.376 E0.95243
G1 X158.582 Y157.58 E0.01217
G1 X158.582 Y157.764 E0.00996 F1199.3
G1 X158.582 Y157.929 E-0.01664 F1180.8
G1 X158.582 Y158.075 E-0.0477 F1124.8
G1 X158.582 Y158.201 E-0.07176 F1032.6
G1 X158.582 Y158.308 E-0.08978 F912.2
G1 X158.582 Y158.396 E-0.10266 F770.5
G1 X158.582 Y158.464 E-0.11135 F613.3
G1 X158.582 Y158.5 E-0.08367 F469.8
G1 X158.582 Y158.526 E-0.07932 F349.5
G1 X158.582 Y158.551 E-0.19527 F145.4
There are lots of this miniretracts and i dont know what they are for.
derdigge
The complete gcode is atteched
t_.zip
(20.71 KiB) Downloaded 23 times
derdigge
Re: Feature "miniretracts" ?
Postby pjr » 04 Nov 2018, 14:34
You have preload turned on. That's the depressurise at the end of the path.
At the start of the path, the opposite occurs.
Postby derdigge » 06 Nov 2018, 02:37
Many thanks for the answer. What nozzle length shall i use?
if i got it right its 12.5mm for a e3dv6 nozzle?
https://www.torwell3d.com.au/products/d ... e-shipping
derdigge
Postby pjr » 06 Nov 2018, 03:30
derdigge wrote:Many thanks for the answer. What nozzle length shall i use?
It's the nozzle bore (or throat) length you need, which for many E3D nozzles is 1.5 times the nozzle diameter (so length = 0.6mm for a 0.4mm nozzle)
EDIT: Just had a look at the nozzle drawing; it may have the same thread and overall length as an E3D, but its internal geometry is quite different :( It appears that the only drawing available shows a 3mm nozzle.
Postby derdigge » 10 Nov 2018, 10:50
Thanks man i go for 0.6 now.
You can be proud of this piece of software! Its not a "beautiful toy" like other. It is a very efficient tool. I love it, it loves me :D
This week i tried to discover the tuning wizards. What a great idea! Are the stls you made them for available? just found the one for temps.
Destringing is an easy draw. But i cant understand the explaination for the preload for example.
derdigge
Postby sinned6915 » 22 Nov 2018, 23:42
I know this is a little stale- attached is the 4 pillar destring that I think lonesock produced at one point.
Preload is not immediately intutive. There are a couple of discussions here and on sublimelayers.com blog posts and youtube videos.
What printer are you trying to tune to? It is really more for bowden machines.
If you have a direct drive extruder, it may not make much difference. We might be able to give you a sense of the range to expect for your hardware.
Same model as temp and flow tuning but with 20% rounded infill. You are looking for the point where the internal stringing stops. Look at the nozzle travel paths to narrow down where to look.
Its a hard thing to cleanly photograph unfortunately.
I run 2 trials- one from say 0-3 and then one near the range from my first iteration results, say 1.8-2.3 if the number is somewhere around 2. iir, it varies the numbers by 10 steps over the 25mm height.
KS_QuadPillars.zip
(9.08 KiB) Downloaded 14 times
sinned6915
Return to Troubleshooting
