better outside loop
MrJ
better outside loop
Post by MrJ »
Hi I`m J from Switzerland
First off all I want to say, that the Kisslicer is really a great software and did the job much better then S3D. After 4 years of printing with different slicers I tried Kisslicer because I saw the blog from sublimelayer ( thanks and really great blog ).
My print quality is so god and tweaking the filament goes so quick. Love it.
Only one thing I can`t setup, I have a little gap on outside, this don`t come from the retract or the preloade ( I tried various time the tuning wizard and different filament ).
I have tested various settings in
Seam Depth
Seam Gap
Join Loop
Loop Order
and nothing helped.
I`m thankfully for every help :)
Bildschirmfoto 2018-02-15 um 15.41.40.png (120.34 KiB) Viewed 1503 times
Bildschirmfoto 2018-02-15 um 15.20.02.png (119.74 KiB) Viewed 1503 times
frozen.rabbit
Re: better outside loop
Post by frozen.rabbit »
It is very hard, if not impossible to hide a seam that has 0 jitter, and is not on a corner.
Check Corners box, and try 360 jitter. That will place your seam on the corner of the model, and will vary position at each layer.
MrJ
Post by MrJ »
Thanks frozen.rabit
The thing is, the gap is a round 1mm deep. How can I correct the seam cap in + and not only in minus?
rantzaus
Post by rantzaus »
Hey J
You are missing a language file for your slicer...
When using that file, it will correct the UI fields..
There are 4 field of interest.
M227 S and P
M228 S and P
There are suck and prime setting at the end and beginning of a loop... Your retract settings to say..
The settings refer to speed and length. Try to search the forum for posts regarding M227 and M228
Regards
MrJ
Post by MrJ »
Hey rantzaus
This was the first thing that I missed when I started with Kisslicer. With other language pack the function doesn`t show up. When I see the videos on youtube, they have the same look ( Kiss 1.6.2 )
thanks
