macOS Big Sur
jonatan
macOS Big Sur
Post by jonatan »
System version: 11.0 Public Beta (20A5343j)
App version: KISSlicer_Mac64_v2_alpha_2.0.6
A small window pops up, blank, no text.
When you select anything from the menu, the application crashes.
KISSlicer 2020-08-14 12-21-17.png (34.35 KiB) Viewed 13544 times
Dorje
Re: macOS Big Sur
Post by Dorje »
Yep. Seeing the same thing on released version of Big Sur now...
dgately
Re: macOS Big Sur
Post by dgately »
Yes, the Alpha v2 does not show most UI...
KiSSlicer v2 a 2.0.6 Mac64.jpg (375.38 KiB) Viewed 13515 times
Pradel
Re: macOS Big Sur
Post by Pradel »
1.6 stable has the same problem with the UI
CrashCoder
Re: macOS Big Sur
Post by CrashCoder »
Does anyone know if this will get fixed? I just upgraded to Big Sur :|
onno
Re: macOS Big Sur
Post by onno »
Same here, just trying to reinstall on my clean install big sur... both stable and beta do not work anymore.
kind regards
Onno
apipe
Re: macOS Big Sur
Post by apipe »
I have a m1 mac now so I have to use big sur and have the same issues
SubseaUK
Re: macOS Big Sur
Post by SubseaUK »
So guys, what is the result? there does not seem to be much in the way of support from KISSlicer.....not the best way to promote the program :shock:
liming
Re: macOS Big Sur
Post by liming »
Is this software alive?
jonatan
Re: macOS Big Sur
Post by jonatan »
Found a way to run KissSlicer on a new version of mac OS. Just use CrossOver and run the Windows version of Kiss. It works very well.
