Material Keep-Warm Temp Can Cause Clog?
I have a dual extruder on my TAZ 4 and I'm extruding ABS at 230 C in the first extruder and HIPS at 230 C in the second extruder. I wanted to set the Keep-Warm temp of the non-working extruder below 230 to prevent the ABS / HIPS from cooking and possibly causing a clog in the hot end; however when I set the Keep-Warm temp to the recommended 65% of the Main temp (230 C) then KISSlicer starts using the previously idle extruder at the Keep-Warm temp (150 C) without giving it a chance to warm up to its Main temp of 230 C before using it to extrude. I'm concerned this in itself will be what causes a clog.
Why doesn't KISSlicer let the idle extruder heat up to its Main temp before using it to start extruding?
Re: Material Keep-Warm Temp Can Cause Clog?
What printer, what firmware, what g-code data in the "select extruder" area?
- Davide Ardizzoia
Hips and Abs are quite free from cooking/clogging (as long as you don't overheat them...if you stay at 240°C you're safe).
The real problem is the extruder oozing...
Cooking is something to be afraid of when you use PVA.
Best Regards
Best Regards
Davide, that's good info, so maybe I need to use a wipe pillar when dual extruding and keeping both extruders at Main temp.
Mikk36, here's my specs:
Printer: Lulzbot TAZ 4
Firmware: Marlin-2014Q3_rB
G-code Prefix tab:
G28 ; home all axes
M203 X192 Y208 Z3 ; Speed limits to minimize skipped steps when moving really fast courtesy of forum.lulzbot.com user 1013
M218 T1 X0.252 Y-55.46 ; Dual extruder offsets
I would like to add some gcode that makes both extruders reach Main temp before either starts to extrude during a print. Perhaps w/ my current materials it is not an issue that could lead to clogging the hot end, but as my material choices expand I would like to make sure I am covered.
Edit:
I think Select Extruder tab gcode is what you are interested in:
; Select extruder, warm, purge
; 5D-style
T<EXT+0>
M104 S<TEMP>
G-code Prefix tab:
G28 ; home all axes
Edit:
; 5D-style
T<EXT+0>
M104 S<TEMP>
Thanks, do you know the variable name for bed temp in Kisslicer? I use <Temp> for the extruders, but that variable doesn't work for the bed.
<BED>inventabuild wrote:Thanks, do you know the variable name for bed temp in Kisslicer? I use <Temp> for the extruders, but that variable doesn't work for the bed.
<BED> does not work as a variable to set the bed temp in the G-code prefix tab. Can you please provide additional info?
Edit - As I'm just learning gcode I did not put S in front of bed <TEMP> variable . Will try that.
I was using the following code and not only did my bed not heat, but my extruders got switched around so Ext+0 became Ext+1 and vice versa. Is it a problem w/ my gcode or a bug in slicer?
T<EXT+0>
M104 S<TEMP> ;start heating EXT+0, no wait
T<EXT+1>
M104 S<TEMP> ;start heating EXT+1, no wait
M140<BED> ;start heating bed, no wait
T<EXT+0>
M109 S<TEMP> ;set nozzlet temp, wait
T<EXT+1>
M190<BED> ;set bed temp, wait
T<EXT+0>
T<EXT+1>
T<EXT+0>
T<EXT+1>
