Hello,
Is it possible to set the support so that only support on the outside faces is created. So for example; a wall with a hole and on top an overhanging edge. I only want support for the overhanging edge, not in the hole.......
Thanks in advance!
No support material inside model
- PenskeGuy
Re: No support material inside model
Guess there needs to be a Support Z-Floor to go along with the Support Z-Roof setting. Then you could set a range that doesn't start at zero.
