Question regarding extruder hardware
Postby abecker » 02 Sep 2018, 13:25
In the extruder hardware, currently I have the values set for my 0.4mm nozzle. If I switch to a 0.5mm nozzle, do I need to change these values or do I only need to change the extrusion width and infill extrusion width?
abecker
Re: Question regarding extruder hardware
Postby pjr » 02 Sep 2018, 13:29
The nozzle throat length will most likely be different; you will have to change that as well. The drive length should not change
Extruder Hardware settings are used to calculate the Preload values.
Postby abecker » 02 Sep 2018, 13:46
I know it is used to calculate the value I put in the preload box, but it is also then used when generating the gcode?
abecker
Postby pjr » 02 Sep 2018, 15:40
Sorry, I wasn't clear.
The G-code preload calculation is based on the filament preload and the hardware (extruder) values; theoretically the filament value should not change when you change hardware.
Return to Tips and tricks
