Cutting an object into kisslicer and printing the two halves
Postby woody3dp » 02 Oct 2017, 08:14
I want to print an object which take a lot of time. So I want to cut it in half to print one half at a time and reduce printing time. I use lower mesh in Z and use a value which is half the height. So it's ok for the top half.
Then I want to print the object from the base until the half, but I don't know how to do it. I don't want it to be flipped upside down. How can I do this ?
woody3dp
Re: Cutting an object into kisslicer and printing the two ha
Postby lonesock » 02 Oct 2017, 17:51
I would first transform the mesh->Flip upside down (also in the model tab's right-click menu), then Lower Mesh in Z. You can load the mesh twice and just invert the second one.
Postby woody3dp » 04 Oct 2017, 02:25
Thanks for your help Jonathan, I think I might miss something because I can't do it. In fact, I want to print:
- first: from the base to the half
- second: from the half to the top
Then I would just have to glue the two parts.
I know how to do the second one: lower mesh in Z and just slice it.
But concerning the first one, when I flip it vertically and slice it, it's printing from the middle of the object to the base (I want to slice it from the base to the half). If I could cut the object, I know I would just have to flip it again and slice...or perhaps there is a way to slice an object only to a desired Z value...
I'm a bit lost...
woody3dp
Postby pjr » 04 Oct 2017, 02:48
For cutting object like this, I use NetFabb Basic (it was supplied in the PR drivers package).
Just cut the model at the Z-height you need and save the 2 parts.
Postby woody3dp » 04 Oct 2017, 08:51
Ok Peter thanks, I thought I could do it into kisslicer itself. I will try netfabb, I never used it before.
woody3dp
Postby pjr » 05 Oct 2017, 06:20
woody3dp wrote:Ok Peter thanks, I thought I could do it into kisslicer itself. I will try netfabb, I never used it before.
Yeah, it really is very simple. I use it quite a lot for model repair; when it can't repair the model, I try MakePrintable.com
Postby woody3dp » 06 Oct 2017, 23:37
Right, netfabb is quite simple. I also didn't know makeprintable, the results are awesome !! :shock:
Thanks.
woody3dp
Postby pjr » 07 Oct 2017, 14:47
woody3dp wrote:Right, netfabb is quite simple. I also didn't know makeprintable, the results are awesome !! :shock:
Thanks.
Yeah, but keep it to yourself; we don't want everyone knowing, do we??? ;)
Return to Tips and tricks
