I use Repetier Host (RH).
But work with KISSlicer in it uncomfortably.
I make simle RepetierHost plugin for KISS.
Plugun started KISSlicer with opened model(s) in RH and after save GCODE load it into RH.
see in github.com
I not found how slice model with command line.
If KISSlicer support command line - I will add it into plugin.
Plugin for Repetier Host
Re: Plugin for Repetier Host
I published new version plugin v 1.0.2
- add support automatic slice from RepetierHost without start KISSlicer UI.
