Reload gcode
Reload gcode
Postby bigsub » 02 Nov 2018, 06:47
Hi to all,
is it possible to reload a gcode file created in the past and see what objects does it contains?
Or I must to reload stl files?
bigsub
Re: Reload gcode
Postby pjr » 02 Nov 2018, 09:28
No, you can use a G-code viewer for this.
I use Craftware to view G-code files; it is an excellent tool for this.
KISS is only able to read the settings used to slice the model from the G-code.
Re: Reload gcode
Postby bigsub » 02 Nov 2018, 13:29
pjr wrote:No, you can use a G-code viewer for this.
Many thanks Peter.
Alex.
bigsub
Re: Reload gcode
Postby whaling » 06 Jan 2019, 14:04
just downloaded it - looks good. Thanks for this, filled a gap in my toolset (currently use blender, meshmixer, kisslicer and now craftware :shock: - would be good to have an end-to-end workflow in one software, but for free software this is an amazing set of tools)
whaling
Return to Tips and tricks
